Problem with actions on textboxes
September 1, 2009 12:00 AM
Well, it seems you can't add actions to checkboxes. I tried in a question and by just adding in a random checkbox item to a page. the only way to trigger something on a check box is to use the onchange tab, or so it seems.
JJS said:In my multiple choice questions, I want immediate feedback, so I've created textboxes with actions that display the textboxes when the user clicks each check box. However, all these textboxes pop up when the user selects AND deselects each check box. How can I program this action of displaying a textbox ONLY when the user clicks to put a check mark in the check box and NOT when they click to take the check mark out of the check box?
