Problem with actions on textboxes
You can accomplish this with a conditional. Insert your conditionals for each choice. If IS NOT EMPTY, then show the box.
I assume you have feedback for each choice. If you have feedback for multiple choices, then add each condition and then make sure you have ANY OF THE FOLLOWING selected.
Kevin
