Problem with actions on textboxes
September 1, 2009 12:00 AM
Unfortunately, I can offer no insight into tests in Lectora. I use a different software for that. But, I know that Lectora is SCORM-compliant, and that would indicate to me that you can indeed set the score. If you aren't using the built-in tests, you may have to define your own score variable and then pass that to your LMS. I'm quite ignorant in that regard.
From what I've seen, the form elements provide more flexibility than the built-in test functions. Usually, such flexibility comes as a price in the form of extra work. It might not be that bad here, though. But I am not the person to ask about this, sorry.
Kevin
