Problem with actions on textboxes
September 1, 2009 12:00 AM
Kevin, I'm now curious about form objects and want to know more. I can see the form's usefulness when you're creating questions to check for understanding along the way in a CBT, but I'm wondering if they are valuable as a test-building tool? If I use forms to create multiple choice questions instead of using the question wizard, can I accumulate a score for the user? Would you recommend using forms this way to build a test?
JJS said:In my multiple choice questions, I want immediate feedback, so I've created textboxes with actions that display the textboxes when the user clicks each check box. However, all these textboxes pop up when the user selects AND deselects each check box. How can I program this action of displaying a textbox ONLY when the user clicks to put a check mark in the check box and NOT when they click to take the check mark out of the check box?
