Problem with actions on textboxes
 Kevin, you've been super. Thanks for all the help you've given me with this issue. I'm currently using Lectora's question wizard for the final tests, and it's working fine. I just thought I might "soup it up" a little, but . . . no worries. Thank you for ALL your help!
JJS said:In my multiple choice questions, I want immediate feedback, so I've created textboxes with actions that display the textboxes when the user clicks each check box. However, all these textboxes pop up when the user selects AND deselects each check box. How can I program this action of displaying a textbox ONLY when the user clicks to put a check mark in the check box and NOT when they click to take the check mark out of the check box?
