Problem with actions on textboxes
September 1, 2009 12:00 AM
So you're saying that the VALUES are the answers to the question, not ones and zeroes.
I don't think that will work with my setup because I have action groups created for each feedback textbox that shows the textbox then hides it after 1 second. That is, unless you can create an action group that consists of action group items???
JJS said:In my multiple choice questions, I want immediate feedback, so I've created textboxes with actions that display the textboxes when the user clicks each check box. However, all these textboxes pop up when the user selects AND deselects each check box. How can I program this action of displaying a textbox ONLY when the user clicks to put a check mark in the check box and NOT when they click to take the check mark out of the check box?
