Problem with actions on textboxes
OK, I think I see where you're going with this. In order for this to work, I think I need to set up each check box as a variable, right? Because the action I've selected when a check box is clicked is to RUN ACTION GROUP. In order to set up a condition, I need to select a variable, right?
JJS said:In my multiple choice questions, I want immediate feedback, so I've created textboxes with actions that display the textboxes when the user clicks each check box. However, all these textboxes pop up when the user selects AND deselects each check box. How can I program this action of displaying a textbox ONLY when the user clicks to put a check mark in the check box and NOT when they click to take the check mark out of the check box?
