Problem Upgrading to 2009
Experienced the exact same problem. As above, the windows install clean up utility solved the problem. In our case, the utility's file list showed a file(installer file?) for a program that had an older version number than the one currently installed. After this file was cleared, the proper installation/update could be done while the windows installer window ceased to appear.
-J
