First of all thank you for your answer.I should clarify the following; I didn't use the module test, I created 4 individual questions in one assignable unit. How can I use AICC_Score on that?I also tried to use AICC_Score in a test created with the module but I got errors from the 1.3.3 RTE. How exactly can I use it? By trying to set the variable I noticed that it only excepted the values -1,0 and 1.As far as know cmi.score.raw (for 2004) can have as a value any integer. Could that be a problem of the RTE's imlpementation? MariaEdited By: maria on 2006-2-15 11:17:21
