Correct me if I'm wrong but I believe that Mastery Score is being sent through the code generated and not the manifest, unless you are talking about having set a mastery score in the preferences of the title.The thing is I am a little confused, because I used to create scorm material with reload editor and I can' t quite grasp the philosophy of lectora on that subject.Is there anywhere I can find examples of scorm material authored in Lectora?And one last question;I've noticed that Lectora generates only SCOs. This means that I can't use a characteristic of scorm which is simple content packaging and creating submanifests, right?Thank you very much for your help!Maria
