Problem reporting score to LMS
If you use the questions outside of the test, then you will need to calculate your own score (from 0 to 100) and set AICC_Score equal to it. SCORM has normalized the the cmi.core.score.raw from 0 - 100. Sounds like it might be an LMS issue ... but I would check the generated manifest and make sure that a Mastery Score is sent.Tim
