The Mastery Score is only in the Manifest. The whole purpose of having it separate is so that the author of the content can change the Mastery Score in the LMS and that changes the behavior of the content without forcing them to re-publish.You can set the Mastery Score property of the AU/SCO ... but that is only so that you don't have to do it during publishing (especially if you have more than one SCO).Simple Content Packaging??? What exactly are you talking about. Ae you referring to just a ZIP file with the manifest at the root? If so, that is exactly what Lectora generates. As to creating sub-manifests, Lectora does not support that concept in it's framework currently. The whole premise of Lectora was to make an easy to use authoring environment so that a Subject Matter Expert could get that knowledge down quickly and easily ... then we do all the work to get that published to the different environments for them: AICC, SCORM, HTML, CD-ROM, etc. So in going for ease of use and publishing to multiple environments, higher level integrations with advanced features in different environments sometimes has to be sacrificed ...Tim
