We use a folder called Extern to hold pdf's that are linked to pop up in the course. This has worked quite successfully in the past. However, we have a course that has a lot of pdf's attached. For some reason when we publish not all the files are being moved. Thus the links do not work on those documents. We can not figure out why some of the files will not move. All names have been checked and they do not appear to be the cause of the problem.
