Preventing course progression unless requirements are met
Is it possible to prevent a learner from proceeding in a course until after they have completed an outside requirement (ex: form, document, process outside of the course). Was thinking about some type of solution where the course would not proceed until an outside requirement has been completed. Can you pass a variable from something into a course to indicate completion, and then allow the learner to proceed only after that requirement has been met?
Thanks in advance if anyone has any advice or tips from doing something similar.
Thanks for that idea, we will definitely explore that option further!
I'm not sure about passing a variable, but you could use a text field as a 'passcode' on a course. After completing the requirement (in-person training, form, etc.) users would be provided a code which they would have to enter into a text field in the course in order to progress.
Could you upload the doc and mark it as a pre-requisite in your LMS?
