Not tried myself. I never use the ppt converted graphic. Integrator always changes size or uses new formats. I prefer to use the original ones i loaded into PPT. Sometimes I find that I can copy a photo and paste as .jpg into Lectora just fine. If not, I go get the original image FROM PPT. Here's how. Take the PPT file and save it as HTML, not a single page, but the one that gives you a sub folder. Open the sub folder and you will find all the images IN THEIR ORIGINAL FORMAT like .jpg, .gif, etc. Sooooo nice. Quality is much better even though you may have to work a bit now to size them right. For drawings in PPT, I copy the drawing and then use SnagIt to capture from the Clipboard. Much beter quality.
