Posted in Files - not sure how this works... please Help!
The issue I see is that is you have a 2 second delay for the AICC_Lesson_Status action and no delay set for the Exit Title/Close Window action. Therefore, the action to modify the variable never gets initiated. Take the delay off the modify variable action and put it on the exit action. Also, if you are publishing to SCORM, I would recommend adding an action after the modify variable action that is set to on click, go to, web address, enter javascript:LMSCommit(); in the url portion and set a 1 second delay. What this will do is set the status when the user clicks the button, then one second later issue the LMSCommit(); call which will pass the data to the LMS API and then one second after that issue an exit command.
