Posted in Files - not sure how this works... please Help!
The reason it is not working for you is that you have the action set to on show for the completion status with conditions. The course only contains one page so if the conditions are not met when the page first loads, then the completion status will not get set. You need to change that to on mouse click and make sure you go through the entire course so that all your conditions are met and the action should then fire when you click the exit button.
