Post Test reset
That sounds like your LMS is doing a score/mastery score comparison and setting the status to pass or fail based on the user's score. That is something that is done on the LMS side, not the course side. So if the user fails the test, if I understand correctly, the LMS sets the course status to failed and will not record any additional course information, is that correct?That sounds like your LMS is doing a score/mastery score comparison and setting the status to pass or fail based on the user's score. That is something that is done on the LMS side, not the course side. So if the user fails the test, if I understand correctly, the LMS sets the course status to failed and will not record any additional course information, is that correct?
