In your case, the LMS has the ultimate control of determining the course status as the course will only pass a status of incomplete unless there is an action in the course to set it to a certain value. Let me know what LMS you are running and I will see if I can find a workaround for you.In your case, the LMS has the ultimate control of determining the course status as the course will only pass a status of incomplete unless there is an action in the course to set it to a certain value. Let me know what LMS you are running and I will see if I can find a workaround for you.
