Does this work in HTML after publishing? I have never trusted the "run" mode for review, or the little test in browser. I usually publish out fully and test. That way I see what the true final view will look like.
You might want to uncheck the use web 2.0 window styles in the publish options dialog if you are still having issues. that seems to be a sore point with this version. Although personally, i've not had any issues with the web 2.0 popups, others have.
murphy said:New at this. Have followed instr. closely. In run mode, glossary pop up appears on cue. Cannot close by clicking on the "close" X (although the X symbol flashes just as it should). Solution?
