Playing audio with question Feedback?
September 4, 2009 12:00 AM
Hi Steve, I can think of two ways to do this both of which invovle building your own feedback mechanisim.
1. use onscreen feedback based on the correct/incorrect response to the answer. This way you can add the audio file to the response and play it only if the response is correct/incorrect.
2. use the popup window feedback and build one for each question you can add the audio to the window to play on show.
Shawn
SkyeSteve said:I am building quiz screens and the client want audio feedback in addition to text pop-ups. there is an option for adding an image, but not sound. Is there an efficient work-around? Thanks in advance, Steve
