There are compression settings that you can change by going the "Advanced Settings" at the bottom of the Publish screen. But, if you are like me and have them on as low as possible, this will not solve your issue.
I actually knew that pixellation was going to be an issue, due to the resizable swf file that publishes out, so I made my images large and high quality to compensate. At first this was working great, my background and other images published wonderfully when tested in the browser. Eventually, I put in more content, and it freaked out and published terribly! I tried to go eliminate the changes to go back to the acceptable version, but since then NONE of my projects have published clearly, even basic image slides. What should I try?
