Passing Var from Flash to Lectora
I've never been so glad I'm not a foxy blonde ;)Glad it worked. As a sidenote, I only tested this with firefox and IE6. You may want to check it against whatever browsers you are supporting. Let me know if you run into any troubles with it. I've never been so glad I'm not a foxy blonde ;)Glad it worked. As a sidenote, I only tested this with firefox and IE6. You may want to check it against whatever browsers you are supporting. Let me know if you run into any troubles with it.
