Passing values from Flash to Lectora
@aaron] ....The variable must also be accessed using a Lectora action somewhere on the page in order to get the variable declared in javascript for that page.So if you make a Lectora variable called 'Test'. Then your flash function might look like this: getURL("javascript:VarTest.set('new value')") [/QUOTE wrote:
I have some top level questions around this issue:Re: the first bit - Im a bit confused. If everything (questions, interface, nav) are in a swf then I presume that the modify var function that you say is required on the page is also triggered by my flash submit button ? what Im asking is does the Tools >> Manage Variables menu area not allow me to declare/initialise varibles...or do I have to do somethign else on each page to ensure this...?and Re. the second comment - when my Flash fucntion modifys the var do I need to add some additional code to send this new value back to the LMS...or does this do it..? Im unclear about the sequence of info passing between flash>lectora>LMS....does info get sent upon each submit, after a defined interval or rather when the exit button is finally clicked?(B.T.W. Im using Lectora as a interface between a "pure" Flash course with content and assessments sitting on individual Letcora Pages. Its needs to be tracked, scored and bookmarked.)thanks !A
