I tried this with the array. But what I found is you need to convert your array to string to store it as a variable in lectora. Then you need to read back in the array and turn it into a string when you want it back.If you are storing a lot of data and need it when the lesson loads, I suggest waiting a few frames for lectora and the Flash plug-in to load, then get your data.SimonEdited By: spuleo on 38638.4086921296
