Page-by-page control of student navigation
This is Technique 28 in my book Lectora 301 - Interesting Courses Using Variables & More.
I copied and pasted the solution from my book. It looks fine in the Edit window but when it posts there is a lot of extra white space. Can't get it out. Sorry.
There are times when you want the learner to progress through a course from the beginning to the end but you still want to allow navigation anywhere in the pages already viewed using a Table of Contents. While there is no way to do this directly using the TOC, you can bounce the learner back if they try to jump ahead.
Warning: This could get real annoying if the learner has already viewed the course and is taking it as a review.
Here are the actions. The variable _largest has an initial value of zero and is a retained variable.
Action Name
On
Action
Target
Value
Type
Condition
get Page in title for calculations
Show
Modify Variable
_pg_diff
Var(PageInTitle)
Set
calc page difference
Show
Modify Variable
_pg_diff
Var(_largest)
Subtract
send them back if too more than 1 page jump
Show
Go To
Back
_pg_diff > 1
save largest page
Show
Modify Variable
_largest
Var(PageInTitle)
_pg_diff = 1
These actions return the learner back to the original page with no indication of what happened. If you want to let them know, then you can add this action before all the actions above. That way it uses the _pg_diff calculated on the jumped-to page, not the current page.
Action Name
On
Action
Target
Value
Type
Condition
This action fires on coming back from “jump ahead” page
Show
Display Message
Std. Msg. Window
You may not jump ahead.
_pg_diff > 1
