Page layout/somthing problems
July 28, 2008 12:00 AM
Keith,What may have happened is that your Blank layout was modified somehow. To fix this, create a blank page, and with that blank page selected, go into Page Layouts, select Blank, and then click on "Replace layout with current page layout." Then click Done.Now double check that you have Blank selected in the toolbar Page Layouts dropdown. Every time you create a page, Lectora will use the Blank layout which should now be remodified to truly be blank.
