No audio with Media Resource characters
Not sure if you covered this already but if you are publishing with compression, the audio file is converted to .flv format. The flash character can't play that type of file...dumb yes. If you go into the scorm package and delete the .flv file and replace it with the original MP3, you may resolve your issue.Not sure if you covered this already but if you are publishing with compression, the audio file is converted to .flv format. The flash character can't play that type of file...dumb yes. If you go into the scorm package and delete the .flv file and replace it with the original MP3, you may resolve your issue.
