next page / prev page help required
Ben Pitman wrote:
On the blocker, why not turn it off in IE Options? There is another option I had to turn on to make things run smoothly:IE > Tools menu > Options > Advanced tab > Security section > Allow active content [check this box] Thank you. I knew there was an option like this because I had used it in the past but I couldn't remember the precise setting. This pointed me to the right option.
