Need Help Doing Something...
I am creating a course focusing on total knee replacement surgery, and trying to include a sort of simulation of the operation.
I have an image of a scalpel and an image of a knee. I want to be able to drag the scalpel over to the knee, resulting in an action where the steps of the surgery are then displayed.
Is that possible? Can I drag and drop without creating a test question?
Discussion (1)
Lectora does not support that unless you use a drag and drop question. You can go to quizzicle.com and there is a free add on that will let you drag items BUT you cannot make anything happen.
If I had to do that, I would use a drag and drop with transparent rectangles over the areas I wanted things to show. First run it in debug mode to see what the values of are in the question variable when you drop on the different places. Then use those in conditions of On Timer actions to test for where the scalpel was dropped to show and hide things. Have one On Timer action for each drop zone and run an action group that shows what you want after it hides the stuff you don't want.
