@pnolan
May 12, 2010 12:00 AM
I have a short swf for user interaction. The user needs to press "pg down" to work through the interaction.
Problem when the page loads they cannot just press "pg down" they have to activate by clicking the swf. From there forward page down works.
Im in Lectora X course will be viewed via IE, SWF is using AS3
The swf is in lectora. I have tried unsuccessfully to get the swf in externally using the instructions on this post
http://forum.trivantis.com/f2/click-activate-lectora-2004-sp3-3396/
Additionally I tried to focus the browser on the swf, I did it wrong or was unsuccessful.
Searches yielded very little could be the terms I searching for.
Any one else run through a similar issue?
Thanks
Patrick
Character Poses in X.5
Action Numbers?
