1.) Can you set the nav bar to only allow the user to proceed to the next slide after the current one has completed? So they cannot skip straight to the end.
2.) Can parent/child hierarchy be hidden until the parent is selected? IE if slide 3 is below 2, and 2 below 1 ... you wouldn't see slide 2 or 3 until the parent has completed.
Both features are avail within Articulate, but I can't seem to find the options within Snap... otherwise everything else I need is there :)
