Navigation not working in scorm output
Hi ThereI'll try to answer these as best I can but my knowledge of the flash side of things is limited as a colleague has helped me with this.The code used is:getURL("intro.html","_self");Stage size in flash is 968 by 714.Stage size in Lectora is 900 by 750Flash version is 7I am embedding the file using the add animation button.I hope this helps let me know if there is anything else you need to know.RegardsEray
