Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Navigation not working in scorm output
@kocagilli
September 22, 2006 12:00 AM
Hi Guy'sJust to let you know the change to the action used in flash has solved the problem thanks for all your help.RegardsKocagilli (Chris)
kocagilli kocagilli
@kocagilli
View Profile
More From kocagilli
Attempts for tests
September 19, 2006 Reply 0 Upvotes
Attempts for tests
Attempts for tests
Audio on/off
September 18, 2006 Reply 0 Upvotes
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Audio on/off
Join The Discussion
Sign Up Login
