Navigation not working in scorm output
My guess is that it's breaking the connection with the LMS because the LMS doesn't know you've gone on to the next page. Rather than using getURL("intro.html","_self") replace the code with getURL('javascript:trivNextPage()'); This should keep the connection with the LMS. My guess is that it's breaking the connection with the LMS because the LMS doesn't know you've gone on to the next page. Rather than using getURL("intro.html","_self") replace the code with getURL('javascript:trivNextPage()'); This should keep the connection with the LMS.
