Navigation between AUs
January 23, 2009 12:00 AM
Thanks Tecocat. That is correct. If you have purchased a support package for your Lectora product and are looking for a quick answer to any question regarding the product, simply do as Tecocat mentioned above. To answer your question, SCORM 1.2 does not support any navigation between AUs. As for SCORM 2004, it does support this but requires to your LMS to handle it as you cannot add links in your course to move the user from one AU to the next. If your LMS supports this, then they will have a frameset around the content and have links to the multiple AUs within the course so the user can navigate from one AU to the next. You cannot include links in one AU to take the user to a specific page located in another AU as that is not supported. Each AU is basically like a small course inside of a large course. They each have their own set of variables. If you would like to see how this works in a live LMS environment, I would recommend you try Test Track, as they work directly with SCORM/ADL to develop standards and this free site offers a place where you can test your content and can give you an idea of how the LMS handles multiple AUs in a SCORM 2004 environment.
