Multiple tests in same title?
Every test you create that is set to be graded, regardless of whether it is included in the overall score or not, creates a score variable. If the test is called Test 1 in Lectora, then the variable Lectora creates for the score would be Test_1_Score. So on your page after each test, you would create an action that states on show, modify variable, select the reserve variable AICC_Score and for the value enter VAR(Test_1_Score). That will set the AICC_Score variable to the value of the Test_1_Score variable. If you don't see the AICC_Score variable in the list of variables you need to right click on the title icon, the top icon in the left hand pane, select properties, content and select the title as an AICC/SCORM/Coursemill title.Every test you create that is set to be graded, regardless of whether it is included in the overall score or not, creates a score variable. If the test is called Test 1 in Lectora, then the variable Lectora creates for the score would be Test_1_Score. So on your page after each test, you would create an action that states on show, modify variable, select the reserve variable AICC_Score and for the value enter VAR(Test_1_Score). That will set the AICC_Score variable to the value of the Test_1_Score variable. If you don't see the AICC_Score variable in the list of variables you need to right click on the title icon, the top icon in the left hand pane, select properties, content and select the title as an AICC/SCORM/Coursemill title.
