Multiple choice question problem
Me again :)I have this massive quiz, and a handful of the multiple choice questions are behaving really strangely once the quiz has been published to HTML.One question is a multiple choice question with multiple correct answers. When you click on choice 2, choice 1 will also select. You can not deselect choice 1 until choice 2 is deselected. One question is a multiple choice question with only one correct answer. Choices 1 and 2 are completely unable to be selected, although the radio buttons highlight when you move your mouse over them.These two problems happen throughout the quiz... but with consistency on various questions (that is for example, the problem happens on question "6" all of the time).I'm using Saba Publisher 5.Does anyone have any ideas as to what the problem could be?I've tried positioning the choices further away from each other, changing the order of layers on the page... nothing seems to help.Thanks!Skye
