Multiple choice question problem
February 10, 2006 12:00 AM
Ben, you're brilliant :)The answers aren't identical they do start off the same way (with the word Yes). I guess that's the problem.I added a space to the end of the first option and everything sorted itself out.So that's the first issue gone... the second issue though is a little different.
Quote:
One question is a multiple choice question with only one correct answer. Choices 1 and 2 are completely unable to be selected, although the radio buttons highlight when you move your mouse over them.
I realise now that what I said before was slightly incorrect, what's really happening is that choices 1 and 2 aren't appearing to be selected, but they really are when you click on them.Any thoughts?Thanks!Skye
