multiple attempt question using web 2.0 popups not working
August 2, 2010 12:00 AM
I have created a multple attempt question that works fine with the regular Lectora feedback boxes, but when i publish and select web 2.0 style popups the feedback doesn't work properly. Instead the web 2.0 popup for the second try appears only for a second and then you get booted to the next page. There is a page done action to go to the next page when the conditions are set but this shouldn not be activated till the User hits the close button on the popup feedback box. As said it works with the standard Lectora feedback box but not with the web 2.0 ones. Any suggestions?
Thanks!
