Greetings,Some of you may have seen this problem before but I coundn't find it (exactly) on the forum.Here is my situation:All of the Lectora courses I have published to the PLATEAU LMS run fine with IE but not with Mozilla FF. I'm getting the following errors:Unable to find an API AdapterI press OKUnable to locate the LMS's API Implementation. LMSinitialize was not successful.I press OKUnable to find an API AdapterI press OKUnable to locate the LMS's API Implementation. LMSGetValue was not successful.I press OKUnable to find an API AdapterI press OKUnable to locate the LMS's API Implementation. LMSGetValue was not successful.I press OKError finding API--too deeply nestedI press OKUnable to find an API AdapterI press OKUnable to locate the LMS's API Implementation. LMSGetValue was not successful.I press OKthe first slide comes up and so on.The LMS owner says I need to modify the findAPI and getAPI functions in the API wrapper file. Does this sound right to you and how do I go about doing this?I'm using Lectora Prof v. 2007 SP4 (4768)Thanks for your help.
