I get the exact same errors when I work with our courses on a local machine. This is because there is no LMS local, and thus the SCORM API could not been set up correctly.Check to see what variables the LMS needs, and set those in your courses.Provided you already did that, there always needs to be a wrapper file that is automatically published with the course, containing a lot of information. It's usually something like a XML file, and you should be able to edit it with any text-editor you like (ok, except for Word and stuff ).I hardly doubt this is browser-related. We run all our courses (published on 2006 and 2007, SCORM and non-SCORM) with IE6, 7, FF2 and all run just fine.How does this react when you use another browser?
