Moving from Test Section to Test Section
Good Afternoon -
I am trying to do some advanced things with Lectora Desktop v21 which may not be supported , but it is worth a try.
Exam Configuration
1x Test
5x Test Sections
10x questions under each Test Section (TS)
When I set each section to randomly chose 2 questions, it functions properly by randomly choosing 2Q from every section in a waterfall process - TS 1 to TS 2 to TS 3 to TS 4 to TS 5 (i've set randomly chose 2Q in each of the 5 sections).
Now, if I want to go from TS 1 to TS 4 - skipping TS 2 and TS 3 - it does not allow me to jump to TS 4, making me go into TS 2, followed by TS 3, and then to TS 4.
I am able to circumvent this required waterfall approach of TS1>TS2>TS3>TS4>TS5 by disabling the randomly choose 2Q in the preceding sections.
Is this by design or a glitch in the software?
Use Case:
I'd like to jump to a section based on user input BUT also be able to randomly choose a set of questions from a pool.
Attached is my test files if you'd like to play with it.
Discussion (2)
Why not just have five tests? You could create a combined score after the user completes the course, if that's required.
You make a good point.
