Minimum system requirements to run Lectora Inspire published content
June 5, 2013 12:00 AM
Hi,
I am looking for minimum system requirements to run the Inspire published content in HTML/LMS.
Thank you.
If your end users are running the content from the web, then we don't require anything specific to the server like Java or Flash. The only thing we specify are the browser versions above.
Of course, if you're using audio, video, and external scripting that require plug-ins, your end users will need to have those plug-ins installed.
Thank you, Laura.
The link helps a bit. I am looking for specifications particularly about processor, RAM, Java version (if any) etc to run the content. I tried searching same in Lectora user guide as well. No luck!
It would be great if you can provide any reference links/documentation.
Courses created for the web or an LMS require Internet Explorer 7.0 or newer or any version of Mozilla Firefox™, Google Chrome™ or Apple Safari®.
You can read the full technical specifications by going to http://lectora.com/e-learning-software/ and selecting Tech Specs.
