Maximum number of questions for a test?
I had a similar problem, but it happened on the 45th question. It has something to do with the amount of memory allocated to hold wrong and right responses. For example, for multiple choice questions, Lectora holds in memory during the test the text of the correct answer and the text of the user's answer. If all of this surpasses a certain amount of memory before the user finishes the test, it stops functioning properly. I got around it by having the answers tagged as A, B, C and D and then manually adding text boxes that would hold the text of the choices. Lectora no longer had to hold the entire text of the choice; it only held A, B, C or D. It saved me a little which was enough to make the 48-question test work.Still, having this happen on the 13th question seems odd unless your questions are set up oddly.
