Maximum number of questions for a test?
October 13, 2005 12:00 AM
The problem as I understand it is that IE only holds 4K of information in a cookie, which means that after IE reaches the 4K limit it does one of two things:1. it will start at the beginning and overwrite the existing data or;2. stop recording information all together.If your questions are in depth and answers long, I can definitely see this happening after 13 questions.I worked around this by doing exactly what Scooterpdx mentions however, I took it one step further and placed the question text in a separate text box as well. By doing this I am still able to ask Lectora to pass all of the question and answer variables in the assessment results.We have developed a 2 character alpha/numeric code that we place in the question text to identify the category of our questions. Along with the answer, A, B, C, or D, Lectora passes this code to identify the question being asked to the participant. I am currently running several assessments online that are working perfectly as explained above. Two of which exceed 140 questions plus.Hope this helps.Regards,Griffin
