Matching question problem
June 16, 2009 12:00 AM
Hello All,
I have been using Lectora for about 9 months and just ran into a matchiing question problem. I have 12 pairs that are matched and when complete a popup shows them a listing of the ones they didn't match correctly. The problem is that if they don't match the first one correctly the answer does not show up. I have it set to show if Question 0001 does not contain 1-1.
I think what is happening is that Lectora is seeing the 10-10, 11-11 or 12-12 answer and reading that as the 1-1. That is just a guess, but it has always worked in the past with less than 10 matches.
I am using Lectora Professional V9 sp1. Is there a work around for this or am I just doing something wrong? (always a possibility)
Thank ouy in advance.
Al.Hello All,
Al.
