Master Audio Control?
I have audio incorporated into my training and have Audio Controllers on each slide. Each slide has a different audio file. If the learner adjusts or mutes/unmutes the volume from the audio controller on one slide, is there a way to apply the adjustment for the rest of the slides within Lectora? I like having the audio controller displayed because it allows the user to pause/replay the audio for the slide if they get interrupted, and it let's them know how much is left to discuss on the slide. If not, is there a way to remove the mute/unmute/adjust volume feature from a controller, just leaving the play/pause & duration features.
I'm not sure it makes a difference, but I have Lectora Inspire vX.5
