Losing images/ not recognizing when I close a title and reopen
March 29, 2012 12:00 AM
Trying to not have to redo an entire title a 3rd time! Last time I closed a title and shut down, when I reopened Lectora and tried to open the title I received an error message followed by a prompt telling me that an image was not supported/ found. Scared to death to close the file and have it minimized until someone can tell me what to do. I've been teaching myself and there's been a huge learning curve. I know there's a screen where you enter supported files. Do I need to load every image and button? I thought Lectora retained that information automatically. Also, if I embed audio, will I lose that as well?
Looking forward to the responses so that I can finally wrap this project up.
Thank you.
Hi,
I have same issue. I got a source file from other group which include images and external folder. However, when I open the .awt file, a message appears says: Unable to load image file..., I checked the images are in the images folder and located in the same directory as lectora file.
Does anyone know how to solve the issue?
I have tried to re-tag the images, but still not workin...
Thanks,
y
If you want, send the source files to me (ss@intea.lv) and I'll take a look. Right now it seems like you are either not doing something right or you've been given wrong source.
The most common reason for missing images when someone sends you a file is that Lectora will not work on a ZIP file. You must unzip the file first and then open the .awt file. Could that be your problem?
