I had this issue on one laptop and it turned out to be a dodgy CD drive. The slowdown was being caused by lots of read errors. I suggest that you check out the general network performance, or CD performance, on the machine that's giving you the issue and see if that is the source of the problem.I did have a similar speed problem on another machine, and I believe that it was down to problems with the antivirus software, but we never really got to the core of the problem before it magically fixed itself.Is your course in HTML or an EXE?If it is HTML, then you will be please to hear that Lectora doesn't use anything "special". It only uses WMP or Flash Player if you have specifically included components that rely on these.Cheers,David
